Differential install "kit"
Old 03-02-2015, 09:01 AM
smitty2919's Avatar
Default Differential install "kit"
I'm planning to drop in a TrueTrac and it was recommended by the friend (that works at a local speed shop) that will be doing the install to also pick up a "install kit".
This will be the first time I have dealt with preparing for a differential swap so I was not 100% on what is included in a "install kit".
Anyone with P/N's for these kits? I'm assuming you can pick them up from Summit/Jegs for a 7.5" GM 10-bolt correct?
Thanks for any help.
Old 03-02-2015, 12:14 PM
Super Hulk Smash
JakeFusion's Avatar
Ratech makes a good one from what I can tell... their part numbers are for Timken bearings for example.
http://www.ws6project.com/user_stor/...tallation-kit/
Old 03-02-2015, 02:01 PM
smitty2919's Avatar
Looking that P/N up on Ratech's website they list Koyo bearings and not Timken ones.
http://www.ratechmfg.com/pop_up_order%20308TK.htm
Looking around at Koyo bearings in general, it seems they are also a very large bearing supplier. I have never heard of them.
I found a Motive install kit on Jegs R7.5GRMKT for $95
http://www.jegs.com/i/Motive+Gear/68...GRMKT/10002/-1
Old 03-02-2015, 03:53 PM
jlaudioholic's Avatar
Default Yukon
Ive read nothing but good about the Yukon stuff http://www.yukongear.com/ProductDetails.aspx?ProdID=970
I've tried the Ratech kit and was not too pleased. Didn't care for the shims included. Ratech had Koyo bearings also, which was actually what I pulled out of my stock unit. The Yukon kit above uses all Timken bearings.
Old 03-02-2015, 04:23 PM
Super Hulk Smash
JakeFusion's Avatar
Yukon stuff is nice.
Motive's kit looks good too with the Timken bearings.
Old 03-02-2015, 08:11 PM
smitty2919's Avatar
Thanks a lot guys.
Quick Reply: Differential install "kit"
