Moser 12 bolt 3 channel to 4 channel conversion
I just bought a 3 channel moser 12 bolt, can i just put moser relucter rings on it and use my stock backing plates or do i need to machine the axle to accept the rings?
LS1Tech Premium Sponsor
most of the time the f-body rearends had the machine work already done on the axles, you should be able to just install the reluctor rings and go. I would strongly suggest the adapters and a set of factory rings if you can find some. We do offer a new ring that is complete oem dimensions if you don't have a source for used ones.
I can get all the parts you need for the job. You will be required to remove the old axle bearings which at that point is just a better idea to install new ones, and a shop press is required to do the work.
Give us a call and we will be happy to get you taken care of!
Moser sells the reluctor rings you need to press into the non-4 channel axles. I did the exact same thing you want to do... The rings fit fine but my abs doesn't work properly now. Not sure of it's the Moser rings or something else, but a lot of other people have had issues getting the abs working with these rears.
