Is this pattern any good?
Old Jul 18, 2015 | 05:34 PM
alvess's Avatar
Originally Posted by 01ssreda4
I ain't gonna lie, I woulda ran that first pattern. And if its a stock type ring and pinion, my bet is it woulda been dead silent.
Would have liked that also, but unforntunatly.. the first pattern was with
old bearings that had been grinded for easy removal.
As it turned out the new bearing had a diffrent pattern.
Hard lesson learned.
Thanks for your honesty.
Old Jul 19, 2015 | 07:22 AM
alvess's Avatar
Default Worse..
Ok, the latest changes made it worse.
Screams like a banshee, not even driveble.
Old Jul 19, 2015 | 08:11 AM
01ssreda4's Avatar
I've never experienced what you're describing and I've used setup bearings since the very first rear end I've ever built. I don't understand why your pattern changed unless the bearing is physically no good. I do notice that going from a used bearing to a new one brings backlash in .001 but that's it. I generally setup tight so I shoot for 7 or 8, and the new bearing tightens it 1 so Im on the tight side of acceptable, but I do that on purpose.
Old Jul 19, 2015 | 11:01 AM
guppymech's Avatar
When I did mine I set it up with a opened up used pinion bearing and my pattern also changed some when I did the final install with new bearings. It was a small change though but I learned next time I'll use a new bearing for set up.
Old Jul 22, 2015 | 04:23 AM
alvess's Avatar
Default Fifth time..
Shims: 0.027
Backlash: 0.007
0.027 is the original shim so it would seem like the new pinion bearing made the backlash decrease (from 0.010 to 0.007).
But still not good.
-Shall try with 0.010 backlash, just to see what happens.
Old Jul 22, 2015 | 04:03 PM
alvess's Avatar
Default Ninth time
Think i get it know, found this guide: http://www.pirate4x4.com/tech/billav...4b_Gear_Setup/
Learned that both the backlash and the pinion depth needs to be in the ballpark otherwise nothing makes any sense.
Now have:
shims: 0.020
backlash: 0.010
and it starts to look good:
Old Jul 23, 2015 | 01:20 PM
01ssreda4's Avatar
Im not commenting because the pattern isnt clear enough for my tastes. You really need to drag the ring gear as you are rotating the pinion.
Old Jul 23, 2015 | 04:36 PM
alvess's Avatar
Default Finaly..
Had it apart 12 times, must be a record.
The only guide that worked for me was this one:
( credit to http://www.pirate4x4.com )
And below picture is showing, as good as it get's with these parts.
Put in the drive axels and tighten the parking brake to get a clear pattern.
The drive side looks a little bit strange, contact all over the tooth.
(install depth 3.785, measured with a vernier caliper)
- Almost silent, very tired of pinions and ring gears but happy with the result.
Thanks for all the help and support!
If i ever do it again it will be with two new pinion bearings, one grinded and one for final assembly.
And with gears from a well known manufacturer.
Starting with measuring the pinion depth, so it gets in the right ballpark before checking with paint.
/alvess
