What Makes the 10 Bolt Rear End So Weak?
Old 08-24-2015, 08:51 PM
  #41
jblankenship's Avatar
my 10 bolt:
best 60' 1.43, times in sig. Has seen some wheel hop but minimal. goes to the track quite a bit and daily driven.
Old 08-24-2015, 08:52 PM
  #42
dailydriver's Avatar
Originally Posted by MidwestChassis2
we have outfitted our fabricated nine inch lighter than a stock 10-bolt.
Even with a nodular iron center and Watts Link??
If so, then yes, I AM impressed!
Old 08-24-2015, 08:58 PM
  #43
Originally Posted by The Alchemist
I'll grab a new rear from the junkyard for $250 and keep on going.
Sadly, there are NO f bodies in the boneyards around here (like the one in Pipersville had no clue what a 4th gen f body is).
I am told that in the mid-west and south, there are HEAPS of them in their yards.
Of course you could always grab an S10/Sonoma axle and adapt it.
Old 08-24-2015, 10:40 PM
  #44
Powers00SS's Avatar
Originally Posted by 01ssreda4
Ya know, ive been here a while, read a few responses, and even posted a few times too, and this response is THE dumbest thing ive ever read. As I lay down to go to sleep in a few minutes, I can only hope I have a heart attack in my sleep, never to awake, so I won't have to see this retarded post in the morning.
I love how dramatic this is lol. I'm glad to see everyone's still chatting about this, I figured there would be a lot of opinions on the subject. I think I will stick with my 10 bolt for the time being and do a few other mods before hopping straight to an aftermarket rear end but I do see that being in my future. When the time comes I will be sure to contact the sponsors on here!
Old 08-24-2015, 11:06 PM
  #45
Carl at CRP's Avatar
Originally Posted by powers00ss
i love how dramatic this is lol. I'm glad to see everyone's still chatting about this, i figured there would be a lot of opinions on the subject. I think i will stick with my 10 bolt for the time being and do a few other mods before hopping straight to an aftermarket rear end but i do see that being in my future. When the time comes i will be sure to contact the sponsors on here!
What Makes the 10 Bolt Rear End So Weak?-11813505_10205235978924401_5343586200555951762_n.jpg
Old 08-25-2015, 06:52 AM
  #46
1 FMF's Avatar
anyone consider the crush sleeve, doesn't the pinion gear get thrusted forward away from the ring gear under load driving the car forward?
if you assemble the rear with a crush sleeve and by design crush the crush sleeve, are you then to expect the crush sleeve will never crush any more? not even under repeated launching of a 3700 lb car from a stop with the forward thrust load generated pushing the pinion gear forward into the crush sleeve?
Old 08-25-2015, 07:27 AM
  #47
01ssreda4's Avatar
That I cant answer for sure. What I can say is that little ****** is pretty tough when you're trying to crush it though....
Old 08-25-2015, 08:15 AM
  #48
MidwestChassis2's Avatar
There is no way to make it lighter with the added weight of a watts link and iron case.
Old 08-25-2015, 11:36 AM
  #49
ss4chad's Avatar
Suspension Tune
Chad
Old 08-27-2015, 02:11 PM
  #50
Marc 85Z28's Avatar
Collapsed crush sleeves are the main cause of pinion seal leaks and pinion bearing failures. That is also why a 7.5" 10 bolt should never have just the pinion seal replaced.
Old 08-29-2015, 07:54 AM
  #51
RockinWs6's Avatar
TY so much! Dumbest? really Dumber than yours? I think not, you win this contest.
Old 08-31-2015, 03:09 PM
  #52
dannyz's Avatar
How so?
Your post didn't make any sense at all.
Old 08-31-2015, 11:13 PM
  #53
SparkyJJO's Avatar
My car ran 12.4 on the current 10 bolt Torsen by the previous owner. No fancy stuff in it either. No ARP studs, no girdle, nothing special at all.
My car also shattered a couple other 10 bolts, at least one of them was an Auburn. Shredded the teeth on one, I think it blew the carrier on the the other but I don't really remember. Wasn't my car yet at the time, I just knew the owner.
I think one of the problems with the 10 bolt is just how variable they can be. You have some that break just by looking at them funny, and then you have others that you try to break and they don't. I'm just glad my car has one of the better 10 bolts in it.
Old 09-01-2015, 09:33 AM
  #54
01ssreda4's Avatar
Originally Posted by dannyz
How so?
But in his mind it did, and that's all that matter to him.
Old 09-01-2015, 09:36 AM
  #55
This post made sense^^. Best post in the thread!
Carl
Quick Reply: What Makes the 10 Bolt Rear End So Weak?
