U-Joint Strap Upgrade??
Just installed my 454 in my 4th gen. Took it for a test drive
and....Bang bang clunk clunk!
Drive shaft broke the U-Joint straps. Not sure why, (installed joint caps on wrong? over tightened bolts?) what ever the case is it sheared off the bolts on one and the other strap broke.
Is there any upgrades to make these stronger? Read on U bolts types, but they were mainly for jeeps and off road rigs. Or should i stick with stock strap and carry and extra set in case they break again.
Thanks!
I finally just settled on the Moog Problem Solver plain old steel ones for my 10 bolt.
you might have to learn this the hard way.....
