Is an Adjustable Torque Arm Needed?
Old Jun 14, 2004 | 09:12 AM
rookie501's Avatar
Default Is an Adjustable Torque Arm Needed?
I am in the process of ordering a 12 bolt. I was told that I needed to get the torque arm. Is this really needed? I am a 6 spd, if that has anything to do with it.
Old Jun 14, 2004 | 09:43 AM
jimmyblue's Avatar
Moderator
You may need it if you changed rear end geometry
(springs > ride height, etc.). Since you don't know
for sure about the 12-bolt's mounting hardware and
your final installed geometry, it's a deal where you
would have to measure pinion angle afterward, and
then possibly have to swap TAs in another session,
vs. doing it all at once (saving some aggravation and/
or shop time @ rate).
Old Jun 14, 2004 | 10:07 AM
rookie501's Avatar
Very good point.
