Driveshaft with 8.8
Old Apr 20, 2016 | 11:18 PM
EvilWS602's Avatar
Default Driveshaft with 8.8
Hi guys. I was just wondering, those of you who has done the 8.8 swap with the 1350 yoke, what driveshaft or length do I need to make this work. Do I need to order a custom driveshaft or can I just install a hybrid u-joint on the factory driveshaft. Thanks in advance.
Old Apr 21, 2016 | 05:44 AM
hiltsy855's Avatar
Hmmm. I'm not sure how a 1350 pinion yoke affects the length. But you definitely can use the stock driveshaft and the stock Explorer pinion yoke (it's 1330 I believe) if you get a Precision 355 u-joint.
Old Apr 21, 2016 | 09:26 AM
Won-Ton's Avatar
Dennys Driveshaft has a lot of information on the yoke lengths.
Old Apr 22, 2016 | 10:13 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
A custom driveshaft is by far your safest bet, especially if you have invested in a 1350 yoke already. The stock driveshaft is very weak and prone for failure. The cost of the repairs from a failure will far exceed the cost of a descent new aftermarket shaft, then you still have to replace the shaft when the repairs are done!
Get with us, we have the best deals on complete new driveshafts in a variety of materials and cost options.
