2.73 gears and a stall.
You might be surprised at how little actual performance difference there is between gear ratios ranging from 2.73 to 3.73 with a 4L60E/LS1 combo and a 3500+ stall speed. You may find this thread interesting:
https://ls1tech.com/forums/new-ls1-o...up-2-73-s.html
you hit the nail right on the head with the 3600 stall from a quality manufacturer unless the car is more of a toy/strip combo then think 4000 yank.Most people come in asking about doing gears with stock stall and an army of members have to convince them to do stall first.
But regardless of your goals, you don't need a specific stall.
Make sure you install a big trans cooler when you ad the stall.
Do you plan on spraying? If not I'd look into yanks PT series or Circle D's E series convertors.
Depends on personal tolerance. Something high quality like a Yank, and then with the high STR of the SS3600, feels generally like stock to me with 3.23s after a week or so of driving it. With 2.73s it's a bit looser, but nothing bad at all and still perfectly fine for the street IMO.
So my 2.73 gears will limit my cam selection in the long run?
Other than that, the entire matter of looseness is a personal perception issue. Some people (the minority) find they are more bothered by "looseness" than others, and in those cases a gear swap can always be done after the stall. It's fine to do gears later, in fact I always recommend doing a stall first. If you want to up the numeric gear ratio later, you can always do that with the converter already in place.
I think the quality of the torque converter is key as to how loose it is. For example, I had a 69 chevelle with a b&m holeshot 3000 with 3.23s, and it was as loose as this fti hard hit I am running now with 2.73s. Basically, the fti is a better converter.
