Q. on replacing my driveshaft
The car is a 2002 Trans AM / M6
On the GM direct sites, they list part # 12568188 as the driveshaft (stating its for Auto) and price of $811.
If I search under 1999 model year, I find part # 12564004 (stating its for Manual) and price of $408.
1. Are these Aluminum shafts & should I go aftermarket Steel?
2. Why different part numbers & prices, I thought all LS1 shafts are interchangeable 1998-2002 years, and interchangeable auto/manual.
GM parts layout catalog lists 7 shafts for 98-02 LS1s'.
98-99 M30 GU5(3.23) 12559525
98-99 MM6 M30 12556670
98-02 MM6 GU6(3.42) 12564004
00 M30 GU5(3.23) 12564003
00-02 MM6 M30 12568187
98-01 MM6 M30 12568188
01-02 M30 GU5(3.23) 12564004
also seen numbers on shafts
12554454
12559525 00 SS
12560725
12564004 02TA auto 01WS6
very confusing
to add to the confusion,I've seen different lengths of CL to CL of 40.5",40.75",41",41.5".
12554454
12559525 00 SS
12560725
very confusing
i did a denny's for around that price, for a 3.5" aluminum with mark williams forged yoke,
this was to go with a new rear axle i put in the car.
in your case if you need a new shaft i would call some of the custom drive shaft builders and get a price quote, you should be able to do much better on price for the standard 3" aluminum with the 3R u-joints and get a regular dana-spicer slip yoke. you would get the whole thing, balanced, and shipped to your door, and because you took the length measurement you know you'd be getting one of correct length.
only thing i dislike about doing it this way is they don't come with a torsional damper pressed on to the slip yoke.
LS1Tech Sponsor
http://shop.brutespeed.com/Driveshafts_c1090.htm
Check out my PST driveshaft prices at this link, the 3.5" alum is the most popular. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
