Newbie... Rear End Issues
Old Apr 27, 2017 | 07:57 PM
EABLZR2's Avatar
Default Newbie... Rear End Issues
I just picked up a 2000 Camaro SS with 65K mi on it. Has the stock rear end gears which was whining when purchased...
It will just be for street use on nice days.
I brought it to my mechanic and whoever was in there last didnt shim things correctly and over tightened a few things. He found metal shavings on the magnet. He was going to try and put things back together tomorrow and see how it goes...after replacing a few things and making the correct adjustments. I will know more tomorrow...
Do I really need to upgrade to a 12 bolt / 9"? I'm thinking a good rebuild on the stock rear end will give me a plenty of years of enjoyment. Only be driven on nice days etc and wont be driven too hard...
What should I do?
Old Apr 27, 2017 | 08:58 PM
LLLosingit's Avatar
Stock will last if it's setup correctly. You would be wasting your money if you never plan on driving it hard on a regular basis.
Old Apr 27, 2017 | 09:09 PM
EABLZR2's Avatar
That's true...
Old May 3, 2017 | 12:04 AM
one sweet ws6's Avatar
M6 or auto
Old May 3, 2017 | 07:48 AM
EABLZR2's Avatar
Originally Posted by one sweet ws6
M6 or auto
M6! 65kmi
Old May 3, 2017 | 04:39 PM
RockinWs6's Avatar
What should I do?
Metal shavings on the magnet would be NORMAL unless its excessive.....whining would be NORMAL unless its excessive, I never heard one that didn't whine a little under load<the gears are small and prone to it>...........there isn't very much to setting up or repairing one of these rears even if it needs ALL the bearings.......... If you are told otherwise Good Luck
