4l80 swap vibrations
Old Sep 30, 2017 | 11:56 AM
rossp's Avatar
Default 4l80 swap vibrations
I finally finished up my 60 to 80 swap. Everything is good except for anything above 50mph I'm gettin a really bad vibration, bad enough that I don't feel comfortable driving any faster to see if the vibration will go away. One thing I did notice with the swap was the weight on my stock driveshaft was hitting the ds loop on my spoon torque arm crossmember, so I had to cut the loop off for the time being. I'm assuming this means the rear of the trans is lower than what the 60 was. If this is the case would this cause that bad of a vibration?
Old Oct 2, 2017 | 03:11 AM
subeone's Avatar
add shims (washers) where your trans meets the trans mount to raise it up and see if the vibration goes away... probably your pinion angle is off by a lot.
Old Oct 2, 2017 | 02:14 PM
rossp's Avatar
Al ready had shims under it but not enough. Got it shimmed up this morning and checked my angles. Trans is pointing down 2.4 degrees and pinion is up 1.5 degree. Still have a really bad vibration. I'm starting to wonder if my driveshaft needs looking at.
Old Oct 3, 2017 | 10:12 AM
cam's Avatar
cam
Pinion angle gets my vote
You can also check for true by placing the vehicle on stands and getting someone to run it in gear to speed and literally look at it from below. Be VERY sure it is safely on stands but if the shaft is out of whack you can usually see it wobble or using a magic marker sloooooowly and carefully lean the tip into the shaft to verify its running concentric.
My local shaft shop doesnt use weights only spins and trues them with heat and cool. Super smooth, everytime
Old Oct 3, 2017 | 08:05 PM
rossp's Avatar
https://www.youtube.com/watch?v=gmV4qwLfOMY
ive adjusted the pinion from -2 to +2 degrees and several in between and I've noticed no difference. My exhaust is rattling a little bit at about 1300 rpms under load. I can't imagine that causing a speed related vibration that makes the car feel like it's going to fall apart though.
Old Oct 3, 2017 | 08:26 PM
cam's Avatar
cam
In a perfect world you want the crank centerline running straight through the pinion and use the suspension for all loading concerns. If your angles are wonky and you run it and look at it, see video I posted for expected behavior if the shaft is your problem re pinion angle concerns. If the shaft is wonky use the marker trick. Dont know what else to tell ya.
Tires/wheels are the exact same config as prior to 80e swap? Nothing else changed? obviously driveshaft is different or shorter with different yoke so thats where im thinking your problem is.
Old Oct 4, 2017 | 11:58 AM
rossp's Avatar
the 4l80 and the yoke are the only things that changed. Driveshaft was reused with a conversion joint. Vibration wise the car was good when it has the 60 in it.
Old Oct 5, 2017 | 05:19 PM
cam's Avatar
cam
Id also check the u-joints. If they are not smooth as butter they could be out of index. Be sure to set them back against the clip.
Old Oct 5, 2017 | 08:34 PM
rossp's Avatar
Finally found the majority of my vibration. My factory trans mount has the metal tab hanging off of the front of it and was sandwiched between the trans and crossmember. I cut this off and it greatly reduced my vibrations. I think getting the pinion dialed in will take care of the rest.
Attached Thumbnails 4l80 swap vibrations-img_1592.jpg   4l80 swap vibrations-679edb0f-1e83-495c-9588-cce7c29cdd21.jpg
