10 bolt pinion seal
10 bolt pinion seal
Just swapped stock gears for 4.10s set everything up with new bearings and my pinion seal leaks. 1 is this seal bad or can it be fixed? 2 if it needs replaced what's the best seal to get? The seal is one that came from motive in their install kit. Thanks
I ran into the same thing a year ago, sounds like you have the triple lip 2nd design like I did. The kit cam with your standard pinion seal. I believe the part number is 12471523
