GM 25 spline yoke with 1350 UJ. Does it exist?
I'm putting a LS3 T56 Magnum in my 66 Chevelle. Leaving the 10 bolt in until I find and build up a 12 bolt.
I need to have a drive shaft made. And I'm wanting to be able to use the same drive shaft when I get a 12 bolt.
According to Strange putting a 1350 yoke will accomplish a common drive line length.
It's a 8.2" 10 bolt with a 25 spline yoke.
Thanks for the help.
Troy
Troy
Like ss1 said a conversion U joint would be your easier route. I used a DS from a chevelle cut it down and used a conversion joint to mate up to the 10 bolt in my Camaro no problem. If your driveshaft shop is worth a damn they should be able to hook you up with the joint. I called up my guy at NAPA but he's been in the parts game for 30+ years, not much stumps him.
