Experience with ratech pinion depth tool??
Old Dec 5, 2017 | 11:40 AM
Dwalt79's Avatar
Default Experience with ratech pinion depth tool??
Looking to change gears in a strange s60 and seen this tool for checking pinion depth. Curious if anyone has used this and could give feedback.
Old Dec 5, 2017 | 08:31 PM
clinebarger's Avatar
I have never seen one like that. I had to look it up.... Very interesting, Not sure I would trust a Dial/Vernier/Digital Caliper for this. I have a T&D Machine pinion depth tool.
The problem I run into has nothing to do with pinion depth gauges, The problem is.....Not every manufacturer stencils the check/installed height on the pinion head.
Nominal Measured Dana 60 Pinion Depth is 3.125", Not that this means much with all the different pinions out there......I tore down a Dana 60 Super the other day to harvest the 3.73 R&P & the measured pinion depth was 3.155"
BUT.....The pinion head thickness was 1.843" which comes out to 4.998" MHD
The Dana 60 MASTER HOUSING DEPTH is 5.000".....So it was actually within .002"
If the pinion head is not marked.....Shoot for 5.000" MHD (Measured pinion depth + pinion head thickness), Then check the pattern.
The following is just an opinion formed over years of rebuilding differentials.....
The BEST ring & pinion gear set is a USED set! 3.54, 3.73, 4.10 Dana 60 sets are easy to find.
They will be fully burnished/broke-in.....No waiting 200 miles to beat on it, The R&P won't shed metal into the gear oil, No early gear oil change, & Less chance of R&P tooth breakage because the "seasoning" & "burnishing" of the contact areas.
Old Dec 6, 2017 | 08:26 AM
Dwalt79's Avatar
Good info! Got to lookin at the gear set I have that's supposedly motive and its not marked :-/
Old Dec 6, 2017 | 08:27 AM
01ssreda4's Avatar
You dont need a depth tool to properly setup a rear end. Pinion depth means nothing.
Old Dec 6, 2017 | 11:43 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^that. I have a couple varieties of pinion depth tools and all they do is put you in the 'ballpark',sometimes not even close to the required pinion shim. Gear marking compound is your final guide.
Old Dec 6, 2017 | 12:13 PM
Dwalt79's Avatar
That's what I was hoping for an inexpensive tool to get me in close and go from there
Old Dec 6, 2017 | 12:26 PM
01ssreda4's Avatar
Still dont need it. Its a waste of time.
Old Dec 6, 2017 | 02:58 PM
erickk120's Avatar
I'm proof of this I've only set 2 rear ends in my life and they are both working as intended. All I needed was some guidance which I got from 01ssreda4/FirstYrLS1Z regarding pattern position. I started with stock OEM pinion shim which wasn't on the ball park but I knew if it was either too far or too close. after knowing what's too far and too close you have a range that you know you can work with and get it smack in the middle. I will say though 5 cut gears felt easier for me. Something with that slanted pattern on 2 cut gears that just makes me shiver.
Old Dec 6, 2017 | 09:32 PM
I agree, You don't NEED a depth tool. But....They can be useful especially if your installing a used gear set out of a different differential as looking at the pattern means nothing.
When building a Dana using genuine Dana-Spicer gear sets......Starting at the MHD will get you really close.
