Need help figuring a noisy S60
Old Jan 26, 2018 | 11:29 AM
Dwalt79's Avatar
Default Need help figuring a noisy S60
Have an 01 camaro auto with a strange s60. Could really use some input on diagnosis or experience. I swapped out a motive 3.73 that was atrociously loud for a Dana 4.10. Replaced the bearings and races as well. Set it up with .008 BL and looked to be a good pattern and preloaded the carrier nuts one hole each. The rear end has a full spool and all heim end suspension and its dual exhaust with turn downs so kinda hard to trace down a noise lol. But when in 4th gear with the converter locked the issue is most prominent. You can hear and feel like an intermittent chattering at a steady speed and load...accelerating feels fine and no chattering when in decel no noise other than just a minimal howl.
