Rear end problems.
Old Apr 18, 2018 | 10:33 AM
Z Prime's Avatar
Default Rear end problems.
Hello i have a 1999 camaro z28 m6..alright so my rear end is making a whine sound and it gets really bad if I go above 50mph. Only when i am pressing on the gas pedal, if I let up the whining stops. When I put my foot on the gas again it starts again.Like almost unbearable. I changed out the fluid, the gears look fine. I changed out the rear pinion seal, filled it back up with a bottle of limited slip fluid and 80/90w and the problem still persists. Any other ideas on what it could be? Thanks
second rear end problem...sometimes when I am turning right I hear a loud bang coming from the rear end. It doesn't happen all the time. So could it be a bad beating? Axle?
Old Apr 18, 2018 | 11:13 AM
01ssreda4's Avatar
Whine sounds like a bearing issue. Bang sounds like a torque arm mount or other bushing issue.
Old Apr 18, 2018 | 01:54 PM
Z Prime's Avatar
It's definitely not the torque arm bushing. There is still a lot of bushing on it.
Old Apr 18, 2018 | 05:56 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
01ssreda4,since he's got a 99 with torsen,could the torsen be failing internally ?
Old Apr 21, 2018 | 08:21 AM
01ssreda4's Avatar
Anything is possible!
Old Apr 21, 2018 | 09:04 AM
Floorman279's Avatar
when you are turning and it bangs, does the car shutter as well? my car did that when i broke 2 teeth off the diff unit
i wouldn't say thats ur issue tho since straight line is not a problem
Old Apr 21, 2018 | 09:18 AM
TTur1996's Avatar
You sure the whine is not coming from the trans, and the banging isn't a broken trans mount?
Old Apr 23, 2018 | 07:07 AM
Darth_V8r's Avatar
Moderator
I've seen loose upper shock mounts, LCA mounts, panhard mounts all cause banging noises under various conditions. Lift the car, let the rear hang, move the axle around and you'll likely find the source
