Reverse problem need help!!!
Old Jun 11, 2018 | 09:38 PM
Knightrider11900's Avatar
Default Reverse problem need help!!!
97 camaro lt1 with t56 tranny Problem I’m having is I put it reverse and when I start letting off the clutch it feels like the rear end is locked up won’t drive back driving forward in every gear no issue seen a post somebody said check caliper bolts did that everything bolted tight I than jacked up rear ended in stands spun the wheels no noises to give possible concern I started the car put it in reverse and there were no issues so it’s when underload having this don’t know much in this field any advice could help
Old Jun 23, 2018 | 07:36 PM
Anybody thoughts?
Old Jul 2, 2018 | 09:52 PM
LilJayV10's Avatar
start buy pulling the diff cover off. If all looks good start looking at the brakes/suspension.
