Axle runout on the S60
Old Jun 17, 2018 | 12:45 PM
01CamaroSSTx's Avatar
Default Axle runout on the S60
After about five passes on the slicks I'm thinking I bent my axles.
Old Jun 18, 2018 | 02:21 AM
TTur1996's Avatar
Is that a new or used S60. If it is new what axle shafts did you get? Hard to believe they bent after a few passes. If its used, whoever may have slid it into a curb to do that.
Old Jun 18, 2018 | 08:52 AM
It purchased from Strange and has 35 spline street/strip axles
Old Jun 18, 2018 | 11:06 AM
TTur1996's Avatar
Wow that's crazy. I would be calling Strange immeadiately. No way that should have happened. I have heard some not so good reviews on those SS axles. We went with the pro series axles. Lots of passes and lots of street driving. All's good so far. Hopefully it will stay that way.
Old Jun 18, 2018 | 05:17 PM
Called Strange this morning and got an RMA# I'll be pulling them this evening.
Old Jun 19, 2018 | 12:34 PM
King23's Avatar
Is it just me or does it seem like problems and strange has been coming up alot here lately? Keep us posted.
Old Jun 19, 2018 | 03:14 PM
Nothing but good things to say about Strange Engineering. From what I've been told by tech support is that the run out at the end of the flange should only be .005 and I'm getting around 0.020 at the flange so I'll leave it up to the pros at Strange to inspect them and get back with me..
Old Jun 19, 2018 | 03:45 PM
King23's Avatar
Well its good they are standing by there products, im in the market for a rear soon and the s60 is high on my list and customer support is key.
Old Jun 19, 2018 | 08:19 PM
Burken01's Avatar
6 speed?
Old Jun 19, 2018 | 08:43 PM
Yes sir!
Old Jun 19, 2018 | 11:25 PM
Burken01's Avatar
Yea this is the 2nd or 3rd time I've heard of them messing up on 6 speeds.
Did you order it assembled? Or did you have assembly done elsewhere?
Old Jun 20, 2018 | 12:23 PM
biketopia's Avatar
Hopefully it's just a fluke. I just picked up a S60 from a member on here with the 35spline axles. Hopefully there are no issues. I'll measure just for ***** and grins before I get into the install.
Old Jun 20, 2018 | 02:06 PM
I'd be interested in seeing what you come up with? I wish I had checked it before installation but had no reason to doubt that everything is as it should be. I retained my traction control and everything seemed to be working fine other than feeling some vibrations up around 80-90 mph. It was after the trip to the strip that I feel something has gone wrong! Now I'm debating if I should keep running the street axles or opt for the racing ones. I've heard of people running the race ones on the street but from what I've been told they are susceptible to snapping as they don't have any give in them.
Old Jun 21, 2018 | 05:39 AM
biketopia's Avatar
I'll stick a dial indicator on em next week when I'm back at the shop and post up my findings. The rear was behind a 4l80e turbo build car, but it never made it to the track and only had about 1500 miles of street driving put on it. But If your's acted up after just a few hits at the track, then we shall see if I'll be replacing/upgrading axles, i sure hope not.
Old Jun 22, 2018 | 04:18 AM
TTur1996's Avatar
Everyone says don't run Pro series axles, pro series gears, or a pro series spool on the street. And that's exactly what we run. We do have 40 spline axles though. Just changed the ring and pinion last weekend for numerical reasons. Been running it 3 years on the street and at the track and the parts showed absolutely no wear. Lash was still .007. Make sure you run the Lucas gear oil they recommend. 85-140 Never have heard anything negative on the pro series stuff. Most everyone I knows runs the pro series Strange stuff. On the street and strip. Never heard anyone saying anything bad on their rear ends. I do know that wheel hop is a axle killer. Stick shift Hell. But usually the drive shaft cuts loose first.
