MWC adjustable trailing arms & centering tire in wheel well
2000 TA WS6 has a Moser 9 inch (stamped housing) w/ LCA brackets lowered car 1 1/4 inch BMR. The tire needs to come forward as its closer to back bumper. The MWC adjustable trailing arms shortened up all the way are the same length as the non adjustable BMR trailing arms. Send them back to MWC? Whats the solution? I didn't want to cut his brand new parts! On my 2000 SS I still have the non adjustable UMIs on mine w/ MWC Fab9 mine is perfectly centered! Trying to get rear axle centered so can put some 28 inch slicks on.
I had a similar issue with BMR and MWC. Realizing i was out of adjustment i made a new hole on my lower relo brackets bc there was room to do so. Moving the hole further back allowed me to regain adjustment room in the arms to come forward more. Be mindful that you dont bottom out the yoke in the trans as you go forward.
Everything seems to be just a bit off when doing anything aftermarket. I couldn't use my non-adjustable UMI LCA's on the MWC rear because the right rear wheel wasn't centered. I didn't take the time to figure out if it was the rear or the LCA's, but it didn't matter. I put a UMI threaded poly end on the body side of the double adjustable MWC control arms and adjusted them to fit. I had thread available on each end of the arms though...they were not screwed in all the way.
what is the pinion angle at? If you move the pinion angle more in the negative direction then it will move the bracket for the lca’s on the housing further backwards. Then you will have more adjustment to bring the housing forward as long as the torque arm and driveshaft allows it.
