Bad axles?
If it was the rear axles or bearings it would be leaving puddles of gear oil everywhere you parked, and the insides of the wheels would be soaked with it.
FYI Axle saver bearings cannot be used on a 4th gen with traction control and a torsen differential. The axles have a thicker flange and the differential has thicker gears. Thats why you can't get the clips out.
