Ring gear runout
I have had used bearing installs where the race no longer is true and caused excessive run out. To save money I used to advise people to take complete gear, carrier and bearings out of a donor diff and reinstall in the diff you want to run but now I recommend brand new bearings every time you pull it apart. Timken or nothing as well. This is the only way to get them really true. So thats my first curiosity. Second if the gears are used Im wondering if the pinion is bent a little causing the backlash issue. So if the bearings are used, replace them all and go again. If the gears are used i'd look there next. Occasionally a carrier or two gets worn out of service as well. The ring gear MUST be tight going on, no slip fit here it must be tight enough that some soft faced rubber hammer or wood and hammering is required to get it seated on the carrier but this would reveal in your run out tests so I doubt thats the case here. Let us know what you find
Richmond is the only choice for a 2 series carrier, a 'thick' set not requiring a spacer,at about $100 more than the 'excel' set.
Motive has 3.90s' but not for 2 series,3 series only. Motive is a popular brand here on ls1tech,probably the most popular brand.
I use richmonds,even used sets. I set them up for maximum strength pattern and disregard noise. I'd rather have a set that won't wear out and noisy than a set that's quiet and won't last long.
I think you're being too picky about highway rpm. For example 2600 with 4.10 would change to 2473 with 3.90. Only 127rpm difference.
I run 4.56s and on long Ohio to Florida trips.
Chasing numbers gets very compromising either with hp or track times. Trap speed tells the tale and that wont change much from ratio to ratio
what size shim do you guys think I should add for my carrier preload? I have read you physically cant really give it too much preload unless your using a housing spreader.
