Easiest rear end swap for 2002 Silverado.
1500 Ext. Cab Silverado. 2wd 6.0 turbo soon to have 4l80e. It has a 10 bolt limited slip. Tired of burning the one tire off and probably the only reason the rear end and trans has lasted. I'm wanting a posi and pretty sure the 8.6 10 bolt isn't going to last. I know the quickest, easiest and somewhat costly (around $1,000) swap is the Vortec Max rearend. I've seen drum style 14 bolt, 6 lug going for around $350-$500. Can drum style rearends be converted to disc using the parts off the 10 bolt? I know gm went back to drum style rear brakes but not sure how it will work where a disc brakes once was. I'm thinking of the abs system.
There's plenty of disc brake swap info around for our year trucks. If you want to keep it simple, pull a 14 bolt FF from an HD truck with disc brakes already on it. The only issue with that is it limits your rim choices and won't match the front, but I believe they make conversions for that too.
