New S60 — which LCA holes?
I have mine set in the lowest set. It's easy enough to move, set em in which ever one you want, then lower the car down and put the full weight on the car and see what your LCA's look like. The general consensus is to have them level or running at an upward angle from the rear to the car. I'm lowered on stranos for what it worth.
You need to use the bottom hole if your car is lowered.
