Help!
Old Nov 11, 2018 | 01:46 AM
prjctSILVERKNIGHTy2k's Avatar
Default Help!
First off,
2001 Ws6
Livernois Heads/cam/intake/200 shot car
Faceplated Tick t56 and hydraulics
ACT clutch
12 Bolt Rear
Full suspension -kmember
(I'm not sure if the rear is a Strange, or a Moser. I havent had the time off to get the car up high enough to look yet.)
Just took my first already built fbody on trade. I've always steered towards stockish fbodys and done what I want with them.
So, just got it running and took it for a drive, and the rear end sounds and looks like it's trying to rip itself out of the car when turning.
Anything more than a quarter turn of the steering wheel in either direction, and the rear end starts banging, the car hobbles horribly, and it sounds like its dragging one wheel or the other.
Had a buddy watch from outside, and he said it looks like its shifting forward and back with every bang it makes. The car drives absolutley perfect with no noise whatsoever in a straight line.
This is my first aftermarket rear in an fbody. I've always had excellent luck beating 10 bolts hard, and with more power than they should even be given gently. What am I most likely looking at? Bearings? Gears? Whole carrier?
Old Nov 11, 2018 | 02:15 AM
LLLosingit's Avatar
Does it have a spool in the rear? When you run a spool rear and try to turn a corner the tire on the outside of the corner is going around a wider radius (traveling further) than the other so it will scrub one of the tires, Usually the tire on the inside of the turn.
Old Nov 11, 2018 | 02:29 AM
LLLosingit's Avatar
Here is an example video of a welded differential ( Poor man spool) Is this similar to what your car is doing?
Old Nov 11, 2018 | 03:32 AM
Pretty similar, but mine seems quite a bit more violent just turning slightly than his did on the lock. I'm afraid to even attempt making that tight of a turn with how harsh it is. It does however seem better at higher speed.
Old Nov 13, 2018 | 09:56 AM
biketopia's Avatar
Pull the cover or contact whomever you bought it from and see if it has a spool. If it's banging around as violently as you say, getting under and giving a good visual on all the rear suspension items and torque arm should point you in the right direction. What size and type of tire is in the rear? If it's a wide sticky tire then the tire bind/scrub can be more pronounced.
Old Nov 13, 2018 | 04:59 PM
The guy I bought it from only bought it to add to his toy collection of somewhere around 20. It sat outside the whole time he had it, and only occasionally got beat up and down the road in front of his farm land. Supposedly it was originally owned and built by someone who worked at Livernois. I think he said his name was Bryan, but that all the information I can really get on it. Lol
Already tried calling Livernois, but they're apparently not very easy to get into contact with. Reasons I buy from TSP. 🤣
Old Nov 15, 2018 | 11:44 PM
It's on 275/60/15 Nitto nt555dr's. Going in nearly a straight line, just barely turning, it almost feels like it's trying to lock up completely. Sometimes it seems worse the others. I turned on the lock yesterday, and it was really no worse than turning slightly. Occassionally it almost seems like its skipping teeth letting the clutch out, but the car is so damn loud that it's hard to tell if it's the rear skipping teeth, or if its wheelspin.
the rear suspension seems fine, theres no play anywhere and everything is bolted in tight.
Old Nov 16, 2018 | 05:38 AM
biketopia's Avatar
Maybe it has a locker in it. Need to pull the cover and inspect and see what is in there.
