S60 vibration at speed?
I just went through this on my lifted truck, shook like I was driving a paint shaker. Lifted it and changed to a 14b rear. Short wheelbase k5. Ended up having a cv joint at the t-case because of the angles involved, even with the angles matching they were just too acute with a typical u joint.
CV swap, it works... however the pinion angle would most likely need to come up substantially as once you have a cv joint in there, there's nothing to cancel out the vibrations on the pinion ujoint at all. So having the pinion at 0 deg would be important.
I had no troubles cruising 120mph+ and roll racing with the stock 10bolt prior to install. Im sure id be on a tow truck home if I try that now.
I did find the problem as I just put the car up on stands with the suspension loaded. rotated the driveshaft and spotted the tailend on the u-joint 1 side was not seated correctly. I removed the driveshaft,rotated it 180* and then slowly tightened it down making sure the joint fully mated. At the same time I installed my new trackbar and panhard bar relocation brackets, double checked everything was as good as can be and headed to the highway. I crept up to higher speeds and had a slight vibration much higher in the 125mph range. Much more tolerable. I know the angle isn't going to be perfect until an adjustable tq arm is put on but Now I know it wasn't a bad driveshaft or joints.
As I was doing a cool down,I ran into some friends and decided to play..hitting boost cut on a hot humid night in a turbocar royally sucks,Im loving the gearing in the s60 with 3:55. So now the next step is an adjustable torque arm to fully dial in the angles. And tone down my wastgate spring as its too high on the street.
