S60 vibration at speed?
Ive put the car up and checked every nut/bolt and retorqued them. Cant find anything that would suggest something was either loose or miss-aligned. Sort of having my tires checked again for balance, Im stuck trying to figure out whats the cause and don't want to find out the hard way at the track trying to run times and something severely goes wrong.
Any suggestions of things to test or look out for would be greatly appreciated.
https://www.bitchute.com/video/TCrxy3AUVzdn/
2nd, the notion that the working angle of the u-joint has no impact on drive train vibration is misinformed and incomprehensible.
3rd, I have a Sonnax yoke and my driveshaft was properly manufactured to the appropriate length for my T56 Magnum.
4th, I can thrash my car down the 1/4 mile and there is no driveline issue to speak of. It is driving at speed around town that the vibration comes and goes. You can actually see the u-joint behind the yoke wobbling in 6th gear.
Is my driveshaft out of phase? NO. Is it bent? NO. Is it balanced? YES. Is it possible for the harmonics of the u-joint with an operating angle of over 4* in the front to balance or cancel the harmonics of the rear u-joint with a 1* operating angle? NOPE. Is there room to shim the transmission enough to make it right? NO. Does the adjustable torque arm have enough adjustment to make it right? NO.
I my car unique? NO. If I knew then what I know now, would I still buy an S60? NO. Have other forum members had issues with nearly every other aftermarket rear end? Yep.
Will a S60 alter the driveshaft angle and u-joint working angles in any f-body in which it is installed? Without a doubt.
Should the people you are advising take that advice? That's their call.
My only advice was to check the working angle of the u-joints. Should the OP take that advice? That's his call. It's neither here nor there to me.
I'd be looking at your M6 gearbox as the culprit.
I had no troubles cruising 120mph+ and roll racing with the stock 10bolt prior to install. Im sure id be on a tow truck home if I try that now.
Why would my t56 now be a problem after install when it wasn't an issue a week before swapping the diff? Its not like the trans was removed or loosend up to be out of line during the swap. From what Ive been told from numerous people and vendors that pinion angle does not change traction but does affect driveline harmonics and when its not correct,I would get the vibration im experiencing now which feels like its coming more towards the rear seat area.
