drive shafts
Old Apr 22, 2020 | 11:14 AM
msystic27's Avatar
Default drive shafts
i understand that for the 2000-2002 camaro there was 3 driveshafts offered depending on model bought. one was the standard drive shaft then came the aluminum drive shaft then finaly stainless steel . can any one help me on how to determine which of the 3 i have?
Old Apr 22, 2020 | 02:33 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The above is not correct.
The determining factor for factory driveshaft selection on LS1 F-bodies was original gear ratio (or one might argue trans type, though this is only true to a lesser degree), it was not specifically model dependent.
There were only two driveshafts: Aluminum and steel. There was no 3rd option. Here is the breakdown:
All M6 transmission vehicles (which were all equipped with 3.42 axle ratio regardless of trim level): Aluminum.
A4 transmission vehicles with base gear ratio (2.73): Steel.
A4 transmission vehicles with performance gear ratio (3.23): Aluminum.
Certain trim levels with the automatic had a mandatory requirement for the performance (3.23) axle, such as SS/WS6/Firehawk - so all of those models would have an aluminum shaft stock, regardless of which trans type they were ordered with, because of the required gear ratio. But, that's not to say that base model cars with the auto couldn't also get an aluminum shaft - all you had to do was order a base A4 Z28 or Formula with the performance axle ratio (3.23) and you'd get an aluminum shaft.
Old Apr 22, 2020 | 02:56 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^ yep.
I believe there was a TSB for 2.73 steel shaft cars that if owner complained of vibration, a aluminum shaft was installed.
Old Apr 22, 2020 | 04:20 PM
msystic27's Avatar
which driveshaft would be stronger
