Slow drip between driveshaft and diff?
Old Sep 21, 2020 | 07:30 PM
05silgto's Avatar
Default Slow drip between driveshaft and diff?
I was recently redoing my fuel system and while under my car I noticed that there is a slow drip on the driveshaft near the diff. I'm guessing the pinon seal needs to be replaced? This is on a 05 gto hence the username.
I don't have any experience yet with the drivetrain but I am pretty mechanically inclined. In order to fix this, I'm guessing I'll need a new pinion seal and preferably a new crush sleeve as well?
Is there anything else I should consider replacing as well while I'm in there? Car has about 87,xxx miles so far. Diff oil changed once at 27k with torco oil and again at 77k. I plan on reusing the oil again as it's expensive but filtering it first.
Also, car was procharged at 75k. Makes between 540 to 600whp. Not sure if there is anything cheap I should consider upgrading while I'm in there? Thanks in advance!
Old Sep 21, 2020 | 08:29 PM
skinumback's Avatar
Fluid can follow the threads out of the pinion where the pinion nut goes. Yes, the correct way to replace the seal is to also replace crush sleeve and reset pinion preload. Put red lock tite on pinion threads and nut to seal it.
Old Sep 21, 2020 | 09:06 PM
05silgto's Avatar
It sounds like your saying the fluid may not be leaking from the actual pinion seal itself but slipping past the pinion threads. This sounds like the exact situation based on where I saw the drip occurring if I remember correctly. I can't go out and look right now as tropical storm beta is currently in my area. If this is the case, is it possible to put a thread sealant and red Loctite on the pinion nut as a quick fix? I'm guessing not since removing the pinion nut would also probably require you to replace the sleeve.
Old Sep 22, 2020 | 08:17 PM
skinumback's Avatar
correct, anytime the pinion nut is removed for any reason a new crush sleeve is required. Some people claim the whole count the treads and put it back plus a little more method works and some get by with it, but there is no right way to do it wrong.
Old Sep 23, 2020 | 11:42 AM
Chris Paveglio's Avatar
One other possibility is what I had - my diff was missing its vent tube and cover... so diff fluid sloshed out during hard braking/cornering/etc and slowly came to the front of the diff housing at the pinion/input. It *looked* exactly like a pinion seal leak. I had a seal replaced and the leak came back, until I discovered the vent tube missing then. And a lot of diff fluid sitting in a valley on the top of the diff housing. Check that first.
Old Sep 23, 2020 | 11:58 AM
cam's Avatar
cam
Overfilling also causes this. I use a little copper RTV in the splines under the pinion flange/yoke.
Old Sep 23, 2020 | 02:57 PM
RedXray's Avatar
If you go with a crush sleeve eliminator kit you can remove the yoke anytime without going through the pinion setup or getting a hernia smashing a crush sleeve. It takes a little trial & error getting the shim pack stacked just right but once done it's not going to change specs.
Old Oct 9, 2020 | 11:13 PM
05silgto's Avatar
The vent tube is fine and the diff is not overfilled, I'm very careful when I fill it. I noticed when I had the back of my car on ramps in the driveway for days since I was working on the fuel system. I'm thinking this may have caused it to drip over time. I don't notice it dripping anymore now that it's not on ramps but there is a lot of grease around the exhaust pipes near this area so I'm not 100% sure.
