F150 8.8 rear end into 4th gen f-body
Old Apr 20, 2023 | 09:10 PM
  #41
john.kiley's Avatar
Originally Posted by Deniedusername
Thanks for the awesome thread. Any issues/ vibrations with the driveshaft angle?
Haven't driven the car yet. I'm on a military deployment. I'll post results when I get back in a couple months! Anxious to try her out, as well as the manual swap which I did at the same time.
Old Apr 20, 2023 | 09:11 PM
  #42
john.kiley's Avatar
Originally Posted by 02_z28_lq4
Would you say thats about a 1/2 inch offset to the right? this swap is looking pretty good, in for driving experience also. Great job John
I'd say it's roughly 2 inches since that is the difference between the lengths of the two axleshafts.
Old Jun 26, 2023 | 05:58 AM
  #43
john.kiley's Avatar
Here’s a look at what the ford explorer caliper brackets look like. They bolt right up. These are explorer discs as well that my machinist re-drilled to 5x4.75. Still have to get the calipers, but they are supposed to clear 15 inch wheels. These are the studs I used as well.
Old Jun 26, 2023 | 06:07 AM
  #44
john.kiley's Avatar
First time rebuilding a diff, I gave her a full bearing job while I was at it. Some of you could maybe chime in on this portion if you’ve ever rebuilt an 8.8 with success. I set the backlash within spec which was .008-.012 in. but it sounded a little loose especially since there’s new bearings which will break in and possibly loosen up. I read somewhere that for a stick car that will see track time, it’s best to be on the tighter end even a little tighter than spec? Anyhow I set it tight and we will see what happens. I have the luxury of being able to take it apart again to check it out fairly quickly so worst case I’ll just reshim.
Also welded the lsd carrier. Was looking at different options but this was the cheapest lol. Running a spool would of required c-clip eliminators which are only available for the smaller variant of 8.8. I’d have to weld on 9 inch ends to run a spool. Lockers are just a lot of money. We will see how she holds up…
Old Jun 28, 2023 | 01:20 PM
  #45
john.kiley's Avatar
Old Jun 29, 2023 | 01:39 PM
  #46
john.kiley's Avatar
here’s what I used instead of the truck style vent, it’s from a mustang.
Old Jul 6, 2023 | 08:24 AM
  #47
john.kiley's Avatar
So first road test yesterday, no weirds sounds, no vibrations so far (low speed around the neighborhood). I will be breaking in the trans as well as the new diff bearings etc in the coming few weeks and will post back up here. Only complaint so far one of the tires squeaks when I go around a tight curve at low speed. Nothing too bad though. This is of course with regular street tires. I will post a couple videos on YouTube. More to follow…
Old Jul 6, 2023 | 10:27 AM
  #48
02_z28_lq4's Avatar
That’s great news, and also the cornering tire chirp is pretty common with a welded diff… what’s your YT channel name?
Old Jul 6, 2023 | 01:39 PM
  #49
john.kiley's Avatar
yeah so I’ve heard about the chirp lol doesn’t really bother me.
i don’t have a serious YouTube channel, I’ve posted a few videos back when I had a supra. I’ll post a link once I put up a video!
Old Aug 2, 2023 | 08:37 AM
  #50
john.kiley's Avatar
Something to watch out for, upper driver side corner of torque arm will slightly hit tunnel. Once it clearances itself, it won’t knock again.
Another view
Problem I ran into was when I mocked up the Antiroll bar brackets I didn’t account for the very thick diff cover, so when I hit a bump it kissed the bottom of the cover. Spaced it out with nuts but will get spacers made.
Closer view
1995 ford explorer brakes are bolt on. I will do a hydraulic e-brake eventually. I believe they will clear 15” wheels.
Old Aug 4, 2023 | 12:25 PM
  #51
02_z28_lq4's Avatar
So could I chop maybe 2 inches off the driver side of the rear end bringing the diff housing closer to being centered? Would that solve the issue with the torque arm clearance?
Old Aug 4, 2023 | 12:27 PM
  #52
john.kiley's Avatar
Well you could but then you’d have to get custom axles made. It’s not a big issue, it only hit the first ride, it basically clearances itself. This was also when my coilovers weren’t dialed in to stock ride height it was lower.
Old Aug 23, 2023 | 11:08 AM
  #53
02_z28_lq4's Avatar
What year Explorer did the caliper brackets come from? I found a good deal on an 91 f150 8.8
Old Aug 23, 2023 | 11:25 AM
  #54
john.kiley's Avatar
97 explorer
Old Aug 23, 2023 | 06:35 PM
  #55
pdxmotorhead's Avatar
The explorer 8,8 is a big go-to for Jeep rear axle swaps. The 8.8 is roughly a Dana 44 and more available.
Lot of Jeep guys running 35" tires on them with ARB lockers.. They are the last level before jumping up to Dana 60 axle conversions.
Old Aug 23, 2023 | 06:44 PM
  #56
john.kiley's Avatar
yes I’ve heard. One of my buddies is a jeep guy!
Old Aug 23, 2023 | 07:04 PM
  #57
john.kiley's Avatar
More road time so far and only good things to say. Very stout feel, 4.10 is a great ratio for the 6-speed. No weird sounds, no vibrations, and the explorer brakes do great back there. Next step will be to work on a hydraulic handbrake setup but that’s for this winter.
Old Oct 12, 2023 | 05:23 PM
  #58
Jaktup95 z28's Avatar
Originally Posted by john.kiley
Just got the racecraft bracket kit in, going to assemble them this week, looks like some pretty beefy brackets.
would these work for a Ford 9 inch housing as well?
Old Oct 12, 2023 | 05:31 PM
  #59
john.kiley's Avatar
they will work for any rear end with 3.25 od tubes on a 3 and 4th gen fbody.
Old Dec 7, 2023 | 10:03 PM
  #60
tyler roady's Avatar
Default Question
Hey man I don’t know if you are still active on here but I’m doing an almost exact identical build and I had a question
