Rotor loose on hub
1st the panhard bar holes aligning or not will not tell you if the axle tube is bent or not.
If your backing plates were bent your axle tube flange is bent and probably the tube also. But how does the backing plate get bent by hitting a curb? Thats a rhetorical question because it doesn't unless you bent the absolute **** out of everything.
Do you have a picture of this?
What happens when you tighten the wheel with a torque wrench? Does it still take not much effort to remove the lugs?
Are you sure the lug studs are seated all the way?
If anything other than the axle and rotor is keeping the rotor from tightening to the axle it has nothing to do with anything else unless the axle won't turn after tightening it down.
Try taking the axle out and putting the rotor and wheel on it and torque it down with a torque wrench. Take a straight edge and see if the axle flange is straight.
And just to be clear you replaced the axle, rotor, wheel, backing plate, bearing, seal. Which of the replacement parts were used?
I know that the shaft was bent because I couldn’t turn the rotor past the brake pads by hand. After replacing it it would spin freely but but for about 1/4 of a rotation it would rub the pads a little. After replacing the backing plate it spins free all the way around.
If the rotor and axle bolt to the bare axle then I assume that means the tube is bent? I don’t have a torque wrench, but the lugs nuts tighten down like “normal” and they take a “normal” amount of force to loosen right after they’ve been tightened. When I was messing with it last I tried to take pics of the rotor to see if it was sitting even all the way around. None of them came out real well. Looking at the pics I realized I’d have been better off measuring the studs to see if they were the same length all the way around the rotor, because I don’t believe they are. Some of the studs appear to be sticking out the rotor further than others. So this brings us back to what? Either the new shaft came bent or the tube is f’d?
If the axle tube was bent enough to cause a problem the axle shaft wouldn't feel right going in. It would be tight. If the tube was bent little enough to not be obvious it would just wear the bearing over time.
The reason I ask about a torque wrench and studs is because sometimes new axles and studs won't be seated all the way and tightening with a torque wrench would ensure they are seated and that they are not stretching from being over-torqued.
I can't picture the rear end right now even though I have a car in the garage and backyard. I'd see if a straight edge could be put on various areas of the axle tube.
Also try to measure or at least eyeball the wheels sticking out. Maybe it didn't bend the panhard bar but maybe it bent the mount. You could take a 2x4 and hold it on the wheel and see if theres equal space from the 2x4 to the body on each side.
Take a ruler or tape measure and see if each stud is sticking out of the axle flange the same amount.
I can borrow a torque wrench from work to see how it is when they’re torqued down to specs. But I bet the probability of the wheel still being loose is high huh because they’ve already been tightened down too far? The studs being all different lengths might make some since as to why the rotor doesn’t slide on easy by hand. I have to slide it on the bottom first and the top will barely have enough stud to get the nut on. Then I had to tighten down the lugs all the way in the same manner as you’d tighten a wheel to get it seated. Would a bent tube have any bearing on how the rotor slides on the hub? The axle shaft slides in and out real easy but I have to lift up its all the way in to get the shaft into the diff. If I don’t it hits a “wall.” That normal? I only had one side jacked up if that makes any difference.
I would think by now the studs are seated.
What brand axle is it and did it come with stud already installed?
Is the parking brake in the way of you sliding the rotor on?
The axle might have come with extra studs of a different diameter, length, or thread for another application (such as older 7.5"/7.625" rears that used SAE studs rather than metric). But if your factory lug nuts screw properly onto the studs then I don't see how the pre-pressed ones could be wrong.
I'm still bothered by the fact that you state (if I understand correctly) that some studs stick out further from the rotor hat than others. That is not right, something is causing the rotor to not sit properly (thus presumably causing the same problem with the wheel), and the "wobble" that results might be the reason it won't stay tight after operation (assuming stud threads aren't damaged).
Really hard to imagine what might be going on without seeing this in person.
If I jack up the rear on one side and put a level on the tire should it be level or will it be off because it’s jacked up on the one side?
These pics were taken last weekend. I was having trouble holding the phone and measuring tape so I didn’t get any that were all that definitive as far as measurements go.
I think it might be the way I was holding the phone to take the pic that makes it look like it’s leaning that much.
Have you checked the bolt pattern to make sure it's a proper 4.75" (120.65mm)? Here's a chart for how to measure, obviously you want the 5-lug version:
Where did you acquire that axle, part number ?
Where did you acquire that rotor, part number ?
This is a GM disc for a brake swap I'm going to do. (probably won't use these rotors just the other parts)
Guess where these Alloy USA axles are made. I don't know but it's not the USA I forgot, I've had these 8 or 9 years now. There are literally a handful (as in 5) of axle manufacturers in the world, especially right now.
Put everything back together and find a shop that does tires and brakes, etc.
Go in there and tell them you need that tire balanced because the weight fell off when you were cleaning it, or whatever.
Maybe ask if they can check the brakes while they're at it.
Get a detailed receipt, maybe tell them you're trying to sell it and want the receipt.
This is apparently too much to do with the limited tools you have so make it easy on yourself. If theres a problem and they don't find it they will be liable. Sounds crappy I know but people do this all the time, just ask a mechanic.
