Mini tub
Old Dec 27, 2023 | 01:12 AM
Jaktup95 z28's Avatar
Default Mini tub
I am looking to mini tub my fourth GEN and put in a quick performance 9 inch, shortened 3”- 3 1/2” inches each side. I read the sticky of the mini tub fourth GEN’s, but I thought I read somewhere that you need to relocate the shock mounts? (On the body) I had seen in their photos that they had NOT done that, And just converted to coil overs. So if I have read this correctly you can do the mini tubs + rear end and the only possible issue that you run into is the gas tank fill spout and LCA’s offset? Any help appreciated thank you!
Old Jan 3, 2024 | 04:36 PM
01ssreda4's Avatar
I didnt have to on my mini tubs....
