Speed Sensor
Old Dec 30, 2023 | 08:53 PM
dmast's Avatar
Smile Speed Sensor
Hello again, I am new here. I recently purchased a 2000 Trans Am. The car is not original, and I do not want it to be original. I am first replacing the original rear end with a Ford 9" Quick Performance 411 possie. I did not realize the original speed sensor setup would no longer work with my new rear. Is there something out there that I can use to replace or make my original sensor work? Can I get it tuned to bypass the old setup?
I am sure someone has been through this, and I do not mean to repeat the question, but here we are, and I am the newbie.
Old Dec 31, 2023 | 09:23 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Did the original rearend have one sensor on top indicating it was a 3 channel ABS only system OR one sensor at each axle end indicating it was a 4 channel ABS & TC system ?
Old Dec 31, 2023 | 09:26 AM
dmast's Avatar
It has two. one on each side
Old Dec 31, 2023 | 09:32 AM
I can't help you, I just posted the question to clarify your situation so other 'posters' might be able to help. It makes a big difference trying to accommodate the needs of the two different systems.
Old Dec 31, 2023 | 09:48 AM
dmast's Avatar
That is fine, and I appreciate the help.
Old Jan 4, 2024 | 03:27 PM
Y2K_Frenzy's Avatar
I believe the problem with the aftermarket rears and the ABS/TCS sensors is the distance from the sensor to the reluctor rings. I’ve read about people trying to use shims to move the sensor closer but I believe most people end up deleting ABS and traction control. The bad part is after deleting them you will still have dash lights on and you can’t turn them off via a tune. So people either smash the bulbs or put tape over them… 🤦🏻‍♂️
Old Jan 4, 2024 | 06:16 PM
dmast's Avatar
I did purchase Reluctor rings from quick performance but I need to press them on. I hope it works. I still want to tune it after I install the rear. I appreciate your reply and I hope I can come back with advice if it does work out for me. I hope you had a great new year.
Old Jan 4, 2024 | 08:05 PM
Y2K_Frenzy's Avatar
Post #128 might be helpful. Happy New Year. #128
