Yet another rearend thread (long)
First off, back in march I hit a 3inch 90 degree dip in the road that construction workers dug up but didn't block off or put up signs. To this day I am still in battles with the city over paying for my damages (which was 4 dented rims, busted center console (yea, it broke the center console when I hit it), and new shocks).
Well, about 2 months ago, I started getting a loud woowooowoowoowoowoo out of the back of the car (actually it's been doing it for a while, but I figured it was the bent rims and tires). Recently it has gotten so loud it over powers the headers, catless Y, and catback. It is loudest at 60 and up but can be heard at all speeds mainly when slowing down and/or holding speeds. It is so loud at 60+ that you will have trouble hearing the person next to you with the radio off and the windows up. Going 75+ you can forget a conversion in the car even with the car in neutral.
Diagnostics I have done
I took the wheels off the car and put the factory wheels and tires on and went for a test run. Same noise (maybe a slight bit quieter). Come back, Jack up the car while a buddy was under the car listening. Turning the wheel, he says it sound like it is coming from the pass side more (but a little on the Driver side), right at the ends where the hub is. No noise from the center. I took the wheels off, took the caliper off, and took the rotor off and spun the hub. It still makes the noise and feels like it turns freely then tightens up, loosens up, turns freely and tightens up again and so forth. After talking to some people we decide it is the rear bearings going bad since my dad had something similar and we replaced them in his 79 vette (which was cake BTW). So I go to the parts store and buy two bearings and seals with a puller to do the job ($25 in parts), and while looking at the hub, realized I don't have a clue how to do bearings on this car. After research I found out you have to dumb the housing and pull a C-clip out and pull out the bearings.
Now questions.
First off, is there a write up on doing this job? I am not very knowledgeable about the rear-ends, but There isn't a job on the car that I haven't been able to do with a little write-up or walk through on the net.
Second, what all should I buy and have ready to replace while getting into this? Anything else you guys think this should be or that I should be ready to deal with since I will have it apart. Where should I get the other pieces (advanced auto had the bearings and seals)?
Again, I don't have money to replace the rear, and don't want to pay the $340+ labor for a shop and like doing my own work to the car so any help would be great.
Now if you push in the axle, it is easy to remove the C clip on the axle. Now just pull out the axle and repeat for the other side.
I know that a picture would help here, but that is the best that I can do.
Mike
IF you have TCS, (not sure which year it started), you will need to take the sensors off to be able to push the axels in (which allows you to take the "C" clip out).
It is pretty straight forward once you get the locking bolt out.
Good luck
Here are the pics of the axle BTW:
The bearings (note, they looked perfect till I fubared them trying to get them out.)
Is it supposed to be so hard to get them out? We were even picking the car up off the jacks pulling so hard!!
