Strange 12 bolt rear end - wheel studs, wheels?
I went through the same thing. I have Bogarts as well. The axles are drilled for 12mm and 1/2 studs. Get the 1/2 studs 3" long. I bent 3 of the 12mm studs on each axle with my old 12 bolt.
To be NHRA legal you have to have open lugs on the rear. The stud has to be at least 1/2 the depth of the nut end of the lug I think. I measured and cut my studs off with a portaband saw. I got some 1/2 beveled lugs from a local speed shop for like $1 a piece to mount my stock wheels. You can't put the plactic caps over them like the stock lugs, but its not too noticeable. At least I won't have to worry about bending studs anymore.
On my 9" I just left the studs 3" long. I may cut them someday, but it doesn't really bother me.
Bruce
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Bruce
