10 bolt leaking
help.
Fry
good way to get excessive yoke wobble and seal
leakage. Seals won't hold unless the pinion runs
true. Also check that there is not too much side
play on the pinion (if there is any you can feel,
might have to tighten the pinion nut some. This
might have implications to your internal setup?).
Could also go up to some heavy weight diff oil
and slow the leakage at least.
