Possible to disable rear ABS?
Can I order a 9inch without ABS/TCS sensors and still get decend braking (abs in front?) wihout the abs inop light????
Look in you Gm Service manual all ABS seams to be is a on/off signal no a mv value.
If i am right you should be able to go to the wiring harness and jump the pins four hi/lo to one of the front wheels. that in turn should turn off the light on the dash. I am going to try it soon when i get a chance.
i do not think it will effect the breaks because the PCM will still see feedback for the too sensors in the front.
What do you think?
What do you think?
