Pulling axle
Old Oct 11, 2004 | 07:06 PM
97LT1's Avatar
Default Pulling axle
Hey ive gotta change the wheel bearing on the passenger back side of a 98 v6 camaro.
Any special tricks to getting at the bearings?
Old Oct 12, 2004 | 03:46 AM
98 Silver Bullet's Avatar
You have to remove the C-clips to pull the axle. Remove the rearend cover. There will be a solid pin in the middle of the carrier that is held in place by a set screw. Remove this pin, push the axle in and remove the C-clip. A magnet is helpful to remove the C-clip. Once the C-clip is removed the axle slides out. You will need a slide hammer to remove the bearing.
Old Oct 12, 2004 | 04:24 PM
Jeffs99SS's Avatar
FYI, if you have 4-channel ABS (traction control car), you will want to remove the abs sensor at the wheel. If not, the axle won't slide in far enough for the c-clip to fall out.
Jeff
Old Oct 12, 2004 | 05:41 PM
97LT1's Avatar
Thanks. Are slide hammers expensive?
Old Oct 13, 2004 | 02:49 PM
97LT1's Avatar
Hey Does anybody know what size the lock bolt for the pin on the carrier is? What is the best way to loosen this? I am on the ground underneath the car, and it is kinda hard to get at.
Also the chiltons book that i have says somthing about a saftey kit to put on non traction control cars for the speed sensor reluctor wheel? Do you have to use this?
Old Oct 14, 2004 | 02:53 AM
RoadHazard's Avatar
You can rent a slide hammer from Autozone.
Old Oct 15, 2004 | 01:39 AM
Jeffs99SS's Avatar
I think the bolt for the pin is either 8mm or 10mm. I just used a boxed end wrench.
Old Oct 15, 2004 | 03:55 PM
97LT1's Avatar
well i dont have room to get a boxed end wrench to move once i slip it on the nut. The nut is surrounded by the carrier itself somewhat. If i try to move the wrench down the part right next to the bolt on the wrench hits the carrier and i can go no further. This is on a v6 is there any difference in the rear?
Old Oct 18, 2004 | 02:25 AM
RoadHazard's Avatar
Might be different then. I don't remember having any problem removing that bolt.
