question about 12 bolt
Old Oct 19, 2004 | 05:40 PM
minty's Avatar
Default question about 12 bolt
Friend bought a used 12 bolt. Went to swap axles and backing plates but the 4 bolts and nuts that hold the backing plates to the rearend dont fit on the 12 bolt. These 4 nuts and bolts are from teh stock rear and the nuts are a little too big. Did new nuts and bolts come with the 12 bolt New? If so, is there anything special about them?.
Old Oct 19, 2004 | 08:57 PM
Z284thgen's Avatar
call moser or strange and tell them you need the 8 T-bolts and nuts for the caliper brackets or you might be able to find them at a local speciality nut and bolt retailer i dont think homedepot or lowes will have them at all
Old Oct 19, 2004 | 11:57 PM
DanZ28's Avatar
The stock bolts won't work, you will need the T-bolts...
Old Oct 20, 2004 | 09:33 AM
1fastWS6's Avatar
Or, just get regular grade 8 bolts and grind one of the flats down until the bolt clears. Doesn't take much to get it to fit.
