Which 12bolt? Moser? Strange?
Im going to be in the market for one soon.... how much did you pay for yours out the door?
TIA.
I can let you know how the install goes when I get mine in. I am expecting to take delivery within the next two weeks.
Moser Pro's- generally cost less than Strange, considerably shorter lead times (usually a week or less from what I have heard)
Moser Con's- seems from information here that Moser's setup quality from the factory is hit or miss, some people complain about torque arm mounting
Strange Pro's- again, from information on here, Strange seems to have alot better build and setup quality from the factory, torque arm mounting just like stock
Strange Con's- More expensive, takes considerably longer to get than Moser (Lead times in the 3-6 week range)
I am sure there are other pro's and con's out there for each, but the ones I listed where what I kept weighing my choice on. I didn't mind waiting longer for something that would be better quality wise. I also am not a fan of the Moser TA mounting, just a matter of opinion.
Also, keep in mind that alot of people have had good luck buying the parts for a Moser rearend and having a local shop install and set it up.
i hear strange whine like hell...on top of that theres a 4 week build time. jus order moser...when you do get it with motive gears...u do have an option.
I will admit my Strange has a mild whine but I'm not bothered by it.
It was noisy at first, but all the noises disappeared during the break-in process (I was *very* cautious with it for at least 800 miles).
It came fully assembled from Moser, with original Moser settings (guys at the shop said that the settings were OK).
Now, after 4K miles, its still dead silent (didn't ran it at the track however, it's a street car).
I'm putting down 399rwhp/411rwtq.
Mark WIlliams STUFF IS EXPENSIVE
http://emporium.markwilliams.com/pro...asp?catid=1046
Starting at 2700.00
and the only thing that changes is the housing. the internals are the same
30 spline axles and 30 spline eaton 800# diff that people are still blowing up.
Only thing it looks like they are doing is casting different housings. Now if Currie makes a stronger housing than the strange then i am all for it but if its the same housing wth the same basic internals we are still in trouble...
My strange housing with axles (33 spline) ran me 1099.99 + 159 cover + 140 yoke=1389
The currie housing with cover and yoke is 939.95 + 399 for axles (31-35)= 1338
So I guess if you are building a 12-bolt from scratch it may be a LITTLE cheaper to go with the Currie
