Grenaded the 12 bolt this weekend.....
Originally Posted by HumpinSS
This doesnt make any sense you can purchase an 33 spline eaton posi and it will fit the moser or the strange 12 bolt so why would this exclude the true trac
I'm going to talk to TrueTrac today and I'll report back.
According to TracTech the pressure angle on the older (6mon. to 1yr. and older) Moser axles is 30* and that's what their splines match. They said Moser has recently switched to an "industry standard" 45* pressure angle. So basically, a new Moser or Strange axle will not work with the current TrueTrac diff. TracTech is retooling the splines now though to match the 45* angle. Those will be available soon.
Also, the 4 series, 33 spline version is not in production yet. Could be 6 months or more. You'd have to use a 3 series and a thick gear.
I think I'm just going to rebuild the Eaton for now assuming the case is still salvageable. Might get the spiders cryo-treated too just for added insurance.
You must have heard some old wives tales huh? Driving on the street with a spool is no more difficult than driving on the street with a locker. Keep you tire pressure just 2 or 3 lbs. under recommended and you have no issues. I've done it for 3 years. I know dozens of people with 8,9 and 10 second cars that have done it longer than me. It's all in how you drive.
I suppose you don't wear white after labor day either.
I also street my spool daily
I remember when I was told that "the trex is too big for the street and so is a spool" then I bought one of each and street it daily
So, with 295-35-18's on the back and driving the car 8k miles or so in a year, in dry weather only, I should go with a spool? I guess a spool is only a $200 gamble. If I don't like it I can just pull it and put a posi back in.
Found out last night that the case on the posi is pretty much trashed also. The carrier bearing was spinning on the housing for some unknown amount of time.
It's your choice. It's either that or keep spending the same money over and over on axles, cases, posi's, gears, and such. You're going to have some good stock in scrap metal. I'm sure some local yards are looking for all the "per ton" scrap they can melt down.
I was wondering, would the physical size of the locker in a 12 bolt make it less strong than one in a 9 inch? That may be something to ask Tractech. Because very few that I have heard about have broken a locker (in a 9 inch) or the actual 12 bolt. Most have broken the posi. So if a locker is going to be as strong and much more streetable (especially a soft locker), why would you go spool? Also, is this your daily driver? In other words, can you wait 6 months for the locker to come out? Could you get by with your old 10 bolt for teh time being? Either way, I wouldnt go back to posi unless it is pretty cheap. But back to my original question, would a 12 bolt locker be as strong as a 9 inch locker?
#33
[QUOTE=matts22]I was wondering, would the physical size of the locker in a 12 bolt make it less strong than one in a 9 inch? That may be something to ask Tractech. Because very few that I have heard about have broken a locker (in a 9 inch) or the actual 12 bolt. Most have broken the posi. So if a locker is going to be as strong and much more streetable (especially a soft locker), why would you go spool? Also, is this your daily driver? In other words, can you wait 6 months for the locker to come out? Could you get by with your old 10 bolt for teh time being? Either way, I wouldnt go back to posi unless it is pretty cheap. But back to my original question, would a 12 bolt locker be as strong as a 9 inch locker?[/QUOTE]
I doubt it. Look at pics of a 12 bolt and look at pics of the 9". You can tell just by looking at them what the difference is.
#34
Originally Posted by 1fastWS6
Problem is nobody has a true locker for a 12 bolt w/ 33 spline axles. The TrueTrac isn't really a true locker, and it's so new that not many people are running one.
I'm putting the stock rear back in for the winter until I decide what to do with it.
I'll prolly be going with the Truetrac. Their catalog lists it as having the 45* pressure angle cuts on it. All I have to find one for is a 4.10 and up and I will put the tests to it.....
1968-72 GM 12 bolt car 33 3.08-3.90 187C198A 914A564 (PA)
1968-72 GM 12 bolt car 33 4.10 & up 914A575 (PA)
(PA) 33 spline units are made to fit axles cut with 45 degree pressure angle.
#35
Originally Posted by Ravenous T\A
M6 + 12Bolt=Boom, I have heard of alot of 12bolts getting trashed with M6's, Wonder if the 9" would be a better choice???
i killed my posi after a few 6000 launches, slaped a spool in it and have been dozens of 1.4 60s with no problem, but they are a screamin, time for a solid crush sleve.
#36
The 4-series TrueTrac isn't in production yet. The tech told me that it could be 6 months or more. He had no clue. You could get a 3-series and a thick 4.11 or 4.56 gear for that though.
#37
LOL even though i read that I was still confused by your post...
The P/N you listed at Randys is the same P/n listed in the catalog for the 4 series diff
#38
These trutracs are not lockers they are worm gear differentials aka torsens. They do
have an extra pinion in them for increased torque handling though. They should be a nice street differential but I don't know how happy they will be with 6500 clutch dumps
on slicks.
on slicks.
#40
14 Second Truck Club
