Lug stud removal?
Old Jan 6, 2005 | 09:51 PM
STL2SLO's Avatar
Question Lug stud removal?
Do not know if I am in the right section here or not but Do you have to pull the axle out in order to change the studs for the lugnuts? TIA
Old Jan 6, 2005 | 10:15 PM
jay_99z's Avatar
I didn't have to. Mine broke off and came out pretty easy. If you are going with stock length to replace, you shouldn't have a problem.
Old Jan 6, 2005 | 10:28 PM
STL2SLO's Avatar
So I can change a lug stud without having to pull the axle out of the housing? Will there be enough room if I just pull all the brakes and stuff off? And yes I am planning on going back to stock length. Thanks, Dave
Old Jan 6, 2005 | 10:47 PM
jay_99z's Avatar
Yeah. When you put the new one in, put a washer on and use a lugnut to snug it up. Once you seat it the whole way you're ready to put brakes and wheel back on.
Old Jan 7, 2005 | 03:59 PM
STL2SLO's Avatar
Cool Thanks, I was realing hoping that I would not have to pull the axle just to replace one stud.
