Backing plates
Old Jan 18, 2005 | 08:21 PM
bowtiegirl's Avatar
Default Backing plates
I'm going to order a 12 bolt tomm or friday and was wondering what all had to be changed over from my old rearend to the moser 12 bolt, i heard something about backing plates being tapped out or something and I also have traction control if that helps .. Thanks in advance
Old Jan 18, 2005 | 11:16 PM
BOWTIE's Avatar
Are you sure you want to go with the Moser? Are you going to pay someone else to check the gear set up. If it was me (and it was a month ago) I would go with a Strange. If you are concerned about downtime and want something that can be ordered and shipped with out having to pull your rear end, check with Billingsley Racing. They are a sponsor, and I believe they have everything needed to have Strange build your rear end complete for you so all you have to do is swap your brakes over and go. Granted this will cost you a little more, because I think he will supply the backing plates and reluctor rings for Strange. The reason Strange does this is so they can completely build your rear end, fill it with fluid, and test it. Moser just sends you the pieces. Also check this forum for ???'s about Moser customer service. FYI, I have the Moser 9" housing and Moser axles for my Billingsley street 9", but he went with Strange on the 3rd member (center section, differential, gears and gear set up, etc.).
Old Jan 19, 2005 | 04:41 PM
bowtiegirl's Avatar
I have read good and bad about both of them and the moser is cheaper but I still need to know about the backing plates....
Old Jan 19, 2005 | 07:07 PM
bowtiegirl's Avatar
anybody else
Old Jan 19, 2005 | 07:10 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Yes, you'll have to swap out the brake backing plates from your stock rear.
Old Jan 19, 2005 | 07:23 PM
bowtiegirl's Avatar
How big of a job is that ? And what else has to be done before I can bolt it in...
Old Jan 19, 2005 | 08:27 PM
Johnny5's Avatar
Make sure you know when you take them off what "L" and "R" are. That is referenced from the rear of the car (not when looking from the front like I did and got to do that step twice )
Old Jan 19, 2005 | 08:30 PM
waltsfastz's Avatar
Not that big of job. Yank your acels out of your old rear. then you can rempve your backing plates. Then press the new bearings that come with the Moser on the Moser axels after you slide the backing plates in the new axels. Then they bolt to the housing. It comes(or at least it did last year) with good direstions. if you dont have a press youll have to take it to a machine shop to do it. After that its pretty much bolting it in. Youll have to fill with fluid and drill a hole or 2 for emergency brake cables.
Old Jan 19, 2005 | 09:49 PM
mitchotoole's Avatar
I believe you have to take the cover off of the old rear and take the c clips out. Then the axles will slide out and then you can take off the plates. Personally I will never do business with Moser again.
Old Jan 20, 2005 | 03:41 PM
bowtiegirl's Avatar
Ok what if I decided to get a rearend that didn't have TCS then it would be a direct bolt in or is there something you have to do for the ABS??????
Old Jan 20, 2005 | 07:23 PM
bowtiegirl's Avatar
Old Jan 20, 2005 | 10:59 PM
Billingsley Racing's Avatar
If your car is factory equipped with TCS, more than likely it has reluctor rings behind the axle flanges. For the ABS/TCS systems to function, your new rearend will require these same rings and the signal they provide.
Hope this helps.
Old Jan 21, 2005 | 06:02 PM
ABS isnt hard to switch over, there should be a little piece with a wire going into it on the top of the pumpkin. I just had to unscrew mine with a ratchet and switch it over to the moser, then just reconnect the wire. Not sure about TCS...I dont have it.
Old Jan 21, 2005 | 06:46 PM
LawmanSS's Avatar
Regardless of whether you keep the TCS or not, the backing plates for the brakes have to be transferred over from your stock rearend to the 12-bolt...hope this helps.
Old Apr 21, 2005 | 05:53 PM
SSkeet's Avatar
I know this post is old, but yes the 4 channel cars are MUCH different. There is nothing on the top of the pumpkin with a 4 channel setup.
If you have ABS and TCS then you have 4 channel ABS and you will have to remove your backing plates and reluctor rings which requires pulling the axles...this much I know for sure.
