? about pinion seal
Old Feb 6, 2005 | 10:11 PM
slow98Z's Avatar
Default ? about pinion seal
My rearend is leeking at the pinion seal. I was wondering if when I replace it if I can mike the crush sleeve and replace it with the solid spacer and the proper amount of shims? The rear is not making any noise so I beleave it's OK.
Old Feb 7, 2005 | 05:25 PM
slow98Z's Avatar
no one has tried or even thought of this
Old Feb 7, 2005 | 05:28 PM
studlybilly's Avatar
I'll bite, why make the crush sleeve? Arent they cheap enough already? Or are you looking at a means of a better design which I'll tip my hat and say goodluck.
Old Feb 7, 2005 | 05:57 PM
slow98Z's Avatar
no not make one thunder racing sells them i'm trying to see if i can install it without tearing the hole rear down?
Old Feb 7, 2005 | 08:01 PM
Uno99's Avatar
Got mine from autozone for 9.95$
Old Feb 7, 2005 | 08:04 PM
slow98Z's Avatar
so can it be done or what ttt
Old Feb 7, 2005 | 08:25 PM
DynoDR's Avatar
Pulling the front pinion bearing is going to be a bitch probably to get the crush sleeve out without teardown.
I would just replace the seal and let it go..
Old Feb 7, 2005 | 08:40 PM
slow98Z's Avatar
what do i need to replace it? torque spects???
Old Feb 8, 2005 | 05:21 PM
slow98Z's Avatar
thanks anyway
Old Feb 8, 2005 | 09:21 PM
DynoDR's Avatar
The seal or what?
Old Apr 28, 2005 | 09:08 PM
98M6SS's Avatar
Originally Posted by DynoDR
The seal or what?
Yeah, the seal. Thanks
Old Apr 28, 2005 | 09:12 PM
6']['9's Avatar
i dont know the tq specs but i went and bought a 4" piece of pvc pipe from home depot that fit inside the ring and hit it in like that. cause its a bitch to get in to begin with.
Old Apr 29, 2005 | 02:53 PM
Houston's Avatar
If it ain't broke, don't mess with it! Replace your seal and leave it alone.
