9 inch install
You'll need either your stock rear's brake backing plates, or you'll need to order some new ones.
-some jackstands (2 for the car to rest on and 2 more for the rear end to rest on once you start unbolting it.
-a floor jack + friends will help to manuver the thing into place
-an air impact will help speed things along with the large bolts tremendously.
-a buddy or two to lift things about, and hold things in place
start by removing the tires/wheels/brakes/parking brake cables. support the brakes (hang 'em over the lower controll arms if you want, ziptie them to make sure. this also keeps them out of your hair) and make sure all the lines are free. there is a brake fluid distribution block thats bolted on by the top torque arm mount. unplug the single abs sensor from the top of housing (for no TCS) or the ones by the outside by the brakes (if you have TCS). make sure nothing will get snagged and/or ripped off when you begin to drop the rear end down.
remove driveshaft straps and remove. you can push it up in the tunnel and wire it to the parkingbrake cables if you dont want any tranny fluid to run out (not much will if you dont care)
remove panhard rod
remove the tq arm bolts and shove toward driverside to free from rear end.
put jack under pumpkin and remove the nuts from the shocks and knock the shocks out of the rear end.
remove the LCA bolts from the rear end while someone steadies it on the jack (person on each side helps)
lower it slowly and grab the springs when they fall out.
when re-installing, i set up jackstands where i think the rear end will need to go (just guess). carry the new one over and place it on the stands. you can slide 'em around wherever you need to get the LCA's re-attatched.
the BEST thing to do with the driveshaft situation, is get the rear mounted, put your stocker in there and see how it fits. then make the determination based on that as to how long your new one needs to be. the stocker should fit fine.
you should do a little research on tq arms that fit with the 9" you want before you order one. again the stocker should fit fine untill you can get one in.
I run my stock alum ds & get a slight vibration at times. I put my buddies carbon fiber ds in & it went away. Needs to be balanced I'd guess. Drop your LCAs to the bottom hole & set your pinion angle to -2 or 3*. Now just HANG ON!
can I order the 9" w/o the exciter rings or brake backing plates to save money if I have the parts from my 10 bolt. what would I have to do to swap these items? is it do you think its worth it or would it be better to have them allready assembled.
how much would this cost to take my stock axle to someplace and get the reluctor rings removed and put on my new axle and I guess the bearings on the backing plates too?
Basically, if you want to resuse the stock TCS rings and backing plates, what is the procedure for swapping them?
I am a little confused on how the 9" setup is, are the axles tightly fitted into the bearings with the backing plate sandwiched between them? there are no c clips on a 9" right?
if someone could post a link with some detailed info on how a 9" is put together I could probably figure it out
