Moser 12 bolt drain plug Hex size??
I want to put some more oil in but i dont want to buy a set of metric hex keys
I just need the hex size for the one on the side by the driveshaft not on the cover. Send a PM if u can thanks
Mine is hex also. It is not a square drive. I will be trying to remove it tommorow for the first time. I will probally try to find a bolt that the wrench side fits into the hex. Then I will weld a not on the threaded end. Then use a regular wrench/socket to remove it(homemade adapter). I do not want to buy a large allen wrench(to cheap). It looks to be around 11/16" or maybe even 3/4" internal hex.
you guys talking about the cover bolt? If you got the TA cover/girdle its the same size as stock, see installuniverisity.com for size, If its the plug on the side it should be square 3/8ths I believe.
Yours is a moser ,right? I just pulled off my cover yesterday because I broke something at the track sunday.Mine is a MOSER also. And if your talking about the cover its a 3/8" hex fill plug and the rest of the bolts are 1/4" hex.On my post earlier some rears have a plug in the side of them in the housing(like mine) that uses a 3/8 square fill plug.
