3.73 Or 4.10???
Experts....help a brother out!!!
pmh
Also NOT ANOTHER ONE OF THESE THREADS! 3.73's are excellent gears for automatics especially with a stock rev limiter. Even so with a raised one for daily driving. 4.10/11's are a bit high for a daily driven vehicle because you'll cruise much higher in the RPM band at a given speed. If you really want streetability id say 3.23's are a minimum and 3.42's will fit nicely. 3.42's are basically better then stock but have little to no difference what so ever. I would go high stall and 3.42's if streetability is a concern and if you have 2.73's otherwise go 3.73's if you have 2.73's. if you have 3.23's KEEP them and get a T/A girdle for your differential youll appreciate it. depending on what kinda daily driving, little to no precipitation get 3500+ and run DR's if its dry/wet get a sub 3500 so id say 3200 tops stall and run dry and wet tires
all in all streetability will never go into the 4's, any 3 will work fine.
JMHO
Adam
