Screetching noise going around left hand turns
Old Mar 12, 2005 | 10:56 AM
speed_demon24's Avatar
Default Screetching noise going around left hand turns
It just started making a screetching noise going around left hand turns. It kind of sounds like metal on metal contact. Does anyone have any ideas what could be causing it?
Old Mar 13, 2005 | 03:21 AM
Sandmann120's Avatar
Posi maybe taking a vacation?
Old Mar 13, 2005 | 08:45 PM
LT1PWRD's Avatar
Has any work been done in that area recently? Maybe the rotor is rubbing against the backing plate. It can be rust on the rotor or a worn out axle in the c-clip area causing the rotor to come in contact with the backing plate. you should pull it apart anyway just to see.
Old Mar 13, 2005 | 10:44 PM
It is definatly a metal on metal contact sound if that makes it any easier to diagnose.
