9" Ford Or GM 12 bolt!!
Both have their downsides.
I'm sure others could elaborate moreso then I could.
Izzo is doing a deal on rears $2500 installed for a 12 bolt. Not sure about the 9" though
9-Inch: Heavy, More power loss then a 12-bolt, fitment issues (on occasion) and hey...it's FORD!
Bos, you may need a 9" moreso then an automatic car would simply because your M6 will put more "shock" thru the rear...
I dunno, I'll let the experts do the talkin.
I think I can actually hear it asking me "is that all i got".
Problem is that my Sucky Star clutch is done and I am now on final 10-day countdown to my A4 conversion.
[ November 30, 2001: Message edited by: SSValet ]</p>
<strong>I have an A4 so do you think i should just go with the 12 Bolt for Weight purposes or do you think i'm going to break it.</strong><hr></blockquote>
Get the 12-bolt. You are not going to break it with your meager hp output. The 12-bolt is much better for a daily driver. Shoot Colonel an email, he will tell you why he got rid of his 9" Ford for a 12-bolt rear on his 9 sec. camaro. There are plently of folks running 9 sec. cars on 12 bolts. The aftermarket 12 bolts have stronger cases than the factory ones ever did and a Moroso Brute Strength posi will survive anything you can throw at it.
The disk is fine, it's the yellow painted,pseudo GM pressure plate that blows.
The conversion is the Yank 4L70 w/ PYE 4000 and some other little goodies.
I've been hogtied with my clutch issues for so long now I'm starting to think my car redlines at 4000.
On 9" it's the centersection. If you go with a cast one you may or may not break it (I did, silverpig99 did) - if you go with a nodular and a billet pinion support then you start to get in the indestructable (at our power level) area.
If the price is similar, go 12 bolt - 9"'s tend to give you problems related to pinion angle and driveline vibration. It can be solved and they can work, no question - it is just a bit mroe work.
As for diff though, I would never consider any posi "indestructable" I have seen even brand new HD posi's that refuse to spin both tires properly in a burnout. Give me a locker anyday <img src="images/icons/smile.gif" border="0">
Chris
