Rear-ends break, yes or no?
Old Apr 1, 2005 | 07:39 PM
RedWS601's Avatar
Default Rear-ends break, yes or no?
I heard the axles break on thses cars after a certain horsepower, is this true? Should I buy a new rear end or ajust axles? please help?
Old Apr 1, 2005 | 07:51 PM
BBQLS1's Avatar
Yep, but you can't really tell when. Depends on A4 or M6, how hard you launch, slicks, super duper pooper scooper clutch, etc.
You can upgrade to a 12 bolt, Ford 9 inch, Ford 8.8. Check out Strange, Moser, and Currie for new rears.
You will probably be safe until you are running 11's or launching at 6000RPMs
Old Apr 1, 2005 | 07:53 PM
RedWS601's Avatar
Thanks, 450 hp is borderline before breaking? have M6 by the way
Old Apr 1, 2005 | 08:00 PM
BBQLS1's Avatar
Depends on how hard the car is launched and how hard the driveline "SHOCKS" the rear.
If you have dynoed 450 at the wheels and the car hooks, I would say that you can easily break the 10 bolt. Some live, but not often. M6 is hard on your driveline especially with a good clutch. My car is close to stock and I am looking into it. I may wait till after I put some headers on it though.
Old Apr 1, 2005 | 08:09 PM
Squintz Palladoris's Avatar
You can kill the 10 bolt with some boltons and some drag radials.
Ask me how I know
Old Apr 1, 2005 | 08:32 PM
BBQLS1's Avatar
Ask me how I know
How do you know? By the way how do you like that 3/4 race cam?
Old Apr 1, 2005 | 08:39 PM
Krab's Avatar
Doesn't really take much to decimate a 10-bolt. A couple of clutch dumps with a tire that sticks should do the trick, especially with an M6. I learned this the hard way also. The stock aluminum driveshaft is also a weak link. Learned that one too...
Old Apr 2, 2005 | 07:46 AM
I killed 2 gear sets on nittos at the track with only long toobs, exhaust, clutch, and a Lid. I never launched higher than 2500 rpm.
With the 9" I now launch at 6500+ and dead hook with no Ill effects on the rearend.
The cam is a g5x3 from LG motorsports n I like it
Brad
Old Apr 2, 2005 | 11:33 AM
6spdpewterZ's Avatar
I went thru a set of gears....... I am dumping the clutch at 6000 on ET streets on the 10 bolt with 4.10's. It still going strong, only hear a slight whine....... but yeah it'll go out in a couple more hard launches..... 9 inch here I come.........
Old Apr 2, 2005 | 11:57 AM
M3EATER's Avatar
Yeah .... they breaK .......
Old Apr 2, 2005 | 12:19 PM
Old Apr 2, 2005 | 01:32 PM
Krab's Avatar
Damn, you decimated that rear. You even managed to take out the housing.
Old Apr 2, 2005 | 02:56 PM
M3EATER's Avatar
The housing broke first (after the carrier bearing on that side blew up) which chewed up the ring & pinion.
That was from road racing. It puts a big side load on the carrier bearings and chews them up.
Old Apr 2, 2005 | 03:22 PM
That **** will buff out Man
Old Apr 2, 2005 | 03:40 PM
02SOMWS6's Avatar
I snapped a axle in half with less than 1000 miles on the car
Old Apr 2, 2005 | 03:54 PM
ULTIMATEORANGESS's Avatar
usually the gears,posi and everything else goes before your axles.
Old Apr 2, 2005 | 06:25 PM
02SOMWS6's Avatar
My axle broke first. Everything else was still good. Car was since 854 miles and snapped the rear befor 1000 miles.
Old Apr 2, 2005 | 10:05 PM
Nasty Hawk's Avatar
Like someone said before, it can happen whenever.. I have been running drag radials from 3,000 miles on the car with no problems.. I only have raced down the track about 7 times, and about 75 street races. Before my gears were installed last sumer i use to launch on the street at 3,500 with no spin and the rear never took a crap, and that is spraying 1st gear after 3,000rpm's.. good luck,
Old Apr 2, 2005 | 10:17 PM
SStheBest's Avatar
whoa....ur pushin ur luck there buddy
Old Apr 2, 2005 | 10:30 PM
Nasty Hawk's Avatar
thats what everyone keeps telling me, but i say dont fix it unless its broke.. But beleive me i have the money waiting for when it does cause in this case it is only a matter of TIME.. LOL
