Paging Trevor & Patrick G re: TPS Shift Control
Old Dec 8, 2001 | 09:36 AM
Ragtop 99's Avatar
Default Paging Trevor & Patrick G re: TPS Shift Control
Do either of you have a write-up on the line pressure/shift by TPS issue? My PCM is going to MTI on Monday and I'm interested in seeing if the changes are something they feel comfortable making. I remember the thread at LS1.com but they are down and there is a risk that they could start from scratch.
TIA <img src="images/icons/smile.gif" border="0">
Old Dec 8, 2001 | 10:29 AM
Tom99SS's Avatar
Default Re: Paging Trevor & Patrick G re: TPS Shift Control
Ragtop,
If I remember correctly, somebody had Ed Wright do this to their PCM. They got it back and A-Tap the car and they really like it. Maybe give Ed a call and ask him about it. I think the line pressure is derived from a couple of inputs (I think on is the MAP sensor, and the other TPS). Going by just the TPS seemed to remove the slipping that some saw via A-Tap.
I maybe wrong about this but this is how I remember tge post on LS1.com
- Hope this helps
Tom <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[ December 08, 2001: Message edited by: Tom99SS ]</p>
Old Dec 8, 2001 | 10:39 AM
Patrick G's Avatar
LS1 Tech Administrator
Joel,
Having your line pressure mirror throttle position is not a bad idea, especially if you run a ported MAF. The pcm looks at "calculated load" when establishing line pressure and a ported MAF will show a lower load. By tying your trans pressure directly to tps, this will eliminate some potential problems of losing line pressure at high rpms. I'd try to see if MTI can tune that in.
Patrick
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 8, 2001 | 10:41 AM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Yeah, what Patrick said. <img src="images/icons/tongue.gif" border="0">
I had Ed set my line pressure to my TPS, and I am pleased with it. I'm still running a stock MAF since he wouldn't tune with a ported one on the car, but I figured it would still be a good idea.
[ December 08, 2001: Message edited by: Trevor D ]</p>
__________________
Old Dec 8, 2001 | 11:10 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
It would be similiar to the way the old 4L60's, non-electronic transmission worked. They had a throttle valve cable to control line pressure, shift points and throttle angle to the transmission, just via a cable. You could even adjust the cable a little to set you shifts a little harder/softer to make a small difference. IMO setting it to the TPS should have been done from the beginning. <img src="images/icons/smile.gif" border="0">
Old Dec 8, 2001 | 04:13 PM
Ragtop 99's Avatar
At what TPS voltage or percent did you recommend having 100% (full) line pressure?
Old Dec 8, 2001 | 04:55 PM
Patrick G's Avatar
If 4.7 volts is supposed to be max tps at 100%, you could back it up to be 100% line pressure at 4.5 volts and go from there.
__________________
Old Dec 8, 2001 | 05:57 PM
Mike Hoffpauir's Avatar
Is this tps/line pressure a paramter that can be adjusted via ls1-edit?
Old Dec 8, 2001 | 09:14 PM
Ragtop 99's Avatar
I was thinking that maybe you might want full line pressure by 3/4 throttle. There's a fair amount of torque at that point on a H&C car with a big converter.
Also due you set it up as an override (i.e. if TPS > 4.5v then 100%, otherwise stock) or do you set up a linear relationship beginning with some non zero value for line pressure % (e.g. 1.0 volt = 25%, 2.0 volt = 50%, etc)
Old Dec 9, 2001 | 04:33 AM
Top Fuel's Avatar
[quote]Originally posted by Trevor D:
<strong>I'm still running a stock MAF since he wouldn't tune with a ported one on the car, but I figured it would still be a good idea.
[ December 08, 2001: Message edited by: Trevor D ]</strong><hr></blockquote>
Sorry to get off topic, but why wouldn't he tune for a ported MAF? <img src="images/icons/confused.gif" border="0">
thanks,
Steve
Old Dec 9, 2001 | 09:30 AM
Patrick G's Avatar
Top Fuel,
Ed Wright is very reluctant to tune for customers with ported MAFs...especially if they send the pcms over UPS. He never knows what to set the a/f ratio at. That's why Trevor and I run stock MAFs.
Patrick.
__________________
Old Dec 9, 2001 | 01:14 PM
If/when I do a heads/cam setup, I'm going to have him dyno tune it with a ported MAF. This way I KNOW it's right and I don't have the thoughts of added HP from added intake flow sitting in the back of my mind. 5 HP is 5 HP! <img src="images/icons/grin.gif" border="0">
IMO, he could make some money on ported MAF ends if he'd carry a set that he can tune for. I can see the home-ported MAFs being a problem b/c he doesn't know how much someone has ported it. However, if he carries a set of plastic MAF ends that he KNOWS is xxx bigger than the stock unit, then I would think he could tune that in with the other mods to hit the proper a/f ratio.
[ December 09, 2001: Message edited by: Trevor D ]</p>
__________________
Old Dec 9, 2001 | 01:54 PM
Ragtop 99's Avatar
He claims the ported MAFs aren't as stable in their readings, but maybe that's because of the inconsistent porting issue.
Trevor: do you have any of the details as to how he programmed for the line pressure. See my last question, re: linear function or override.
Thanks <img src="images/icons/smile.gif" border="0">
Old Dec 9, 2001 | 08:42 PM
Tim98TA's Avatar
From: From the Bowels of Hell!!! You want some of me bitch?!?!?!
[quote]Originally posted by Ragtop 99:
<strong>I was thinking that maybe you might want full line pressure by 3/4 throttle.</strong><hr></blockquote>
Wellin a drag racing application, that really doesn't fall into play due to the fact that once you leave the line, you are at WOT for the duration of the run.
I would do as Patrick said and have it tuned about .2-3v below the suggested value of WOT being 4.7v.
Tim
Old Dec 9, 2001 | 09:09 PM
Ragtop 99's Avatar
Tim: I agree for racing, I was just wondering on the street in passing situations, etc whether that would help with longevity.
Old Dec 9, 2001 | 09:18 PM
JS's Avatar
JS
Ed does have ported MAF halfs that he tunes for..
I have them....
JS
